Hi,
2012 FJ Cruiser. Driver side rear stop light recently went out. Passenger side stop light illuminates correctly. All other rear lights work—both sides. Sounds like a bulb issue.
Opened hatch to left rear lights. Verified all lights, only stop (brake) lamp not illuminating. Removed the stop lamp plug from the rear light cluster. Replaced old bulb with new Sylvania 921 bulb.
No joy. Tried the other 921 in the blister 2-pack. No joy. Meanwhile the passenger side stop light is operating normally. Sooo… maybe not the bulb?
Not a hint of corrosion anywhere in the 921 connector or entire rear light area… it’s all plastic outside the connector anyway. What about fuse? I have passenger side stop lamp, so fuse must be good, right?
Never a beach truck, corrosion free. Never had a tow hitch or custom wiring. All OEM equipment as original. Wiring hasn’t been fiddled with. No signs of mice, driven daily.
What comes next? Is there a brake light switch somewhere up front? Could a ‘bad’ brake light switch illuminate only one side?
Chip
Chip
