After totalling my 80 and buying it back from the insurance company, I'm checking everything under the hood before going too far down the path of a buggy build. I noticed that both ends of the plug for the EGR Temp Sensor were smashed and held together with a zip tie. Apparently the guys that did my head gasket have screwed me again (had a leaky valve cover gasket after they told me it was replaced and later found it was not
My first thought was to just buy a new sensor and replace the wire & plug that it connects to, but I'm not sure that would work as that wire might be part of a major harness. I'm thinking a better approach might be to just replace the plugs themselves since the terminal inserts appear to be OK.
Does anyone know if these are a standard size plug that I can purchase and then just insert these terminals back into, or do I need to find these exact parts from Mr. T?
)My first thought was to just buy a new sensor and replace the wire & plug that it connects to, but I'm not sure that would work as that wire might be part of a major harness. I'm thinking a better approach might be to just replace the plugs themselves since the terminal inserts appear to be OK.
