troubleshooting after rollover
  1. Remove sparkplugs? Check.
  2. Place towels along head to catch oil? Check.
  3. Close hood to contain oil blasting out of Cylinders? ....
  4. Crank it up? Check. Oh s***! I got oil everywhere. Gotta close that hood!
So, I got the oil out of my cylinders and was able to crank her up (no more starter outrunning the flywheel). Got all the oil cleaned up (well most of it anyway) from missing #3 in the list above. After I reinstalled the plugs and cranked her up, she ran about 2-3 seconds then quit. Every time I've started it after that I get about a second or maybe two, then she just quits. Still smoking a lot, so I'm guessing there's still oil to be burned. Anybody got an idea of where to look next, or do I need to just keep cranking it up until all the oil is burned off?
After sleeping on it and a little research this morning, I'm going to pull the fuel pump relay and try to clean it up. The brake fluid dumped out of the reservoir and this whole area was wet, so it's very likely that this relay (which was pretty much directly below the brake fluid reservoir) is not working properly. I'm unable to hear the fuel pump priming up when I turn the key, so I'm thinking this might be a good place to start.
Your plugs might be getting fouled if there was that much oil in the cylinders. I would pull one to see if its still getting drenched from residual.
I pulled the #4 spark plug (since #4 cylinder had the most oil). It was oily, but not drenched. I cleaned it off and reinstalled it.
I installed a known good fuel pump relay from a donor vehicle and tried to crank it once more, but there is no change. It cranks up, seems to run for about a second (showing 1000 RPMs) and then dies. I am still not hearing the fuel pump prime up, so I'm still looking in that direction. Is there some safety shut-off feature that is engaged in a rollover?
You can try bypassing the relay and just jump the pump in the pannel. Or you can also try spraying some carb cleaner down the intake tube for a few sec to see if stays running.
I think I've eliminated the relay by putting in a known good relay. Even after installing the relay from my donor vehicle the fuel pump does not make any noise, so it seems that it's not priming up. I'm trying to research this now while maintaining the appearance of actually working :grinpimp:
I'm out of spray carb cleaner. Just a "pour bottle" of B-12 (not even sure where that came from). Will run to town shortly and pick up some throttle body cleaner and shoot it in the intake while trying to crank it up.
Now I'm starting to wonder if the wiring that I have removed from the interior might have been related to the fuel pump. However, in second guessing the second guessing of myself, I have removed no more wiring from the interior of this vehicle than I have from my donor, and the donor still has power to the fuel pump. Back to researching.....
... It cranks up, seems to run for about a second (showing 1000 RPMs) and then dies.
If it's fuel related, could be the circuit opening relay, FPR, or related wiring.
IIRC, the OBD2 doesn't run the fuel pump till the starter is running.
The fuel pump should prime once the key gets to the ig on position.
Not on these. It's what @Tools R Us stated.
If no fuel pump, it would point to possible cranks sensor or other control.
Check for spark using a timing light. If you have spark, then the crank sensor is working.
Any CEL with the key in run, but not running?
Thanks @Tools R Us and @BILT4ME . I wasn't sure if the pump would run before the starter (e.g. when the key was engaged), but was thinking I should hear it priming up. Do you recall where the circuit opening relay is located? I'd like to lay hands on that and see if swapping it out from the donor truck will get it running.
No CEL light at all.
My wife will be back from town shortly with throttle body cleaner and contact cleaner, so I'm hoping that some combination of these will sort this out.
If the CEL isn't on with the key turned to run, the bulb is burned out or there is a power problem to the ECU. If there is a power problem it the ECU, all ECU related stuff isn't going to work correctly, including the fuel pump, not going to run. On a rig that has been heavily jolted, like been on it's lid, I would check the normal connection points, fusible links, the single big connector by the distributor, harness by the EGR pipe, etc.
FWIW, this wasn't a "hard" rollover so much as a "layover". I just turned it over 25% (on the driver's side) and slid a long ways.
The CEL is not illuminated when the key is turned on (various other lights come on like diff locks, ABS, brakes, airbag, battery voltage but then turn back off), and I'm 99.999% sure the CEL bulb is still good, so based on your statement I'm going to assume that I have a connection issue to the ECU. I will start going through those connection points.
After holding the intake valve open and hosing it with throttle body cleaner, I was able to get it to run for about a 7 count. No obnoxious clanking or banging, so I think once I locate this electrical issue I should be in high cotton...
You need to start here for your troubleshooting tree.
80-series FAQ
Have you verified spark using a timing light? If no CEL = no power to ECU = no spark.
80-series FAQ
I will start looking through the FAQ for this. I was trying to look through the FSM but haven't found anything to go on from there.
I don't have a timing light, nor do I know how to use one... self taught and 100% novice mechanic...
It would seem that I'm getting SOME spark as I've had it running for 6-7 seconds with throttle body cleaner for fuel. Could this mean that I have power TO the ECU, and just not connection FROM the ECU to somewhere?
It didn't really point out that you want to start at the "Emergency Troubleshooting Procedures" section at the bottom of where that opens......
That makes sense about running briefly that you have spark, but something is preventing it.
I don't know if there is a rollover fuel cutoff switch buried under the dash somewhere........Maybe someone can help with that?
No worries; that was easy enough to find. I'm looking through Scenario 3 in Emergency Troubleshooting Procedures now. Will report back if I have any epiphanies or more questions!
Thanks to all of you for the guidance on this! It's this sense of community that makes owning a 21 year old vehicle possible for someone without the requisite skills and experience!
UPDATE for those that contributed to this thread and anyone who might be facing a similar issue in the future:
If you have removed the intake hose that runs between the filter can and the manifold, the ECU will not send power to the fuel pump. Apparently the ECU requires the MAF Sensor to detect & report air flow before it will send power to the fuel pump.
I had removed my filter can and all the hoses from the intake to clean the oil out. The vacuum hoses were in place, but not the intake hose when I tried cranking it again. Once the intake hose was in place and the MAF Sensor could detect airflow, she started right up.
