Trouble Code 26 solutions? Does your fpr click?
White bluff, tn
I just purchased a 94 fj80 with 168k. I had a steady check engine light with code 26. I replaced the coolant temp sensor and the steady light went out, now there is an intermittent light with the 26 code stored. It has stalls and has little power when taking off usually when cold. It also has a slight surge while driving. The only odd thing I can find is the fuel pressure regulator clicks when the motor is revved above idle speed. I have never owned a Toyota and have never had a vehicle's fpr do that so I am not sure if that is normal for fj80s.I have replaced the following: plugs, wires, cap and rotor, coolant temp sensor, fuel filter, fixed exhaust leaks, throttle tube, pcv, various vacuum lines. The egr valve was replaced 6 years ago and the o2 sensors look fairly recent. Thanks for any help.
I don't recall my 94 fpr clicking. It's vacuum operated so no reason for any clicks that I can come up with.
When you move the throttle and vacuum is applied it makes a single click, let off and it does it again. My vanagon had a throttle switch that clicked when it returned to idle and that is what I thought it was at first. So I'll try a new Fpr. It has only been driven about 10k since 2004. Maybe I will get the bugs worked out soon.
Sounds like it may be a problem in your iac valve. Maybe a frayed wire going to it or its hanging up. The click should be heard after ignition is cut off. When started cold it should be high idle and step down continuously. I would guess it does not.
Check to see if the transmission cable is hooked up to the throttle.
Unplug the O2's and drive. The 94 can run without the O2 hooked up. You will get a CEL but don't worry about that. If it drives and runs fine them replace them. I have driven many thousands of miles with O2's unplugged.
