Trollhole Carb
Picture of the close but not correct Aisan float, and a new Land Cruiser Aisan float. Both of these parts are made by Toyoda Gosei for an Aisan carb on a Toyota application, but only one is for the DD38/40 Cruiser carb.
Here is the inline filter I installed. I have some concern with it getting too hot and melting potentially. That would suck. Where have others installed theirs? I wanted it somewhere that I could see it when I opened the hood.
ZAooZgN7f1KpHDHgkgi_M7exV031W5fboK5VBmDyn8mQ3oCJpmD9y5v8SmQkKNAiIFrvdxJBDQEERJc2butit5mtK3Di9wxt3_DCrFMas37TH-rBG7D7hDz3GbFCLMDByiG00KL50UszfQb1ChE9Q3Zj0ZQHwyZCbx0hpOO-buOXoSE2E042bzY2ha3oS-_iEkp6z6BAjgUYj1XAN4EAktla3ho3ww65bSnv60EsTmy4FNxA27aXsNjohXogDWEvdHVNKifWbtnfJe88GNtgd9xrBVa3NgKJcLOygVV7VbIa1L3HKHo_GitBqjqR3uiQ_EU_GhRv8aitBKCQVk8-uyXEdDtJy0i-Y87-27grcRpY3ifHakDYX8GC31Mi6JYTiDiuYwyBWbSpE2RSw6R80pqXtMOho3aUAl0vqt8r1oF0fNRSGtgW14IJMG1pxNi-7rN2qeu-GeN5-2IGfxHN7rp3oUQjLBnhXIbYIr4IdMsa-KJQzx1l_YuA5wjR6UEG65I-WxY5NZnUlRaHFkyTXDQvkW_A3T7ZX5UisPTOfqk3XSXCsjwDc5cmSgSc03TX0_duIIKiHukxLSlB3p5iacPB9703Rxe7_vze_nNa=w1620-h911-no
Apparently the trollhole carb does not come with the metal stud to attach the air cleaner. I really don't want to pull my stud off my OEM carb plus the trollhole is short by about 1/2" so I would need to check and see if it is the correct length. What are others doing for the stud?
Okay, yes that is what I was referring to. Is the float strong enough to resist the continual pressure from the pump without a return? I’ve seen some float adjustments bend even from 5 or 6 psi.
Good question, that I do not know. Trollhole has stated that the return line is not needed. How would I check this, rig up a pressure gauge on the fuel line after the pump?
Here is the fuel pump that I have. Appears to be original. I pulled it out apart, cleaned and painted before I reinstalled it at one point in the build.
I have no idea if I have a regulator in-line. First I had heard of this, how do i tell?
HqdUHY5x6c6Jakro_U8kYrkKvO_CIMfYrJvwNUykik_2jQ-BsZgOqUKm00czaiXUwPx-r7ZYsVAeGHN1XUeEmlb84A_7bu9QlNYlNLHGoft2W4favyGhd3Dr5RvdM3_hy-MVn4f68vawAMQTCcdTrbKx3XYNq-KzcDAYIYPWtb-lHhiYW0DR4mGQEApud4xkH0mm96GLlDNLWuiaVJP_Za-VzuNysK3aieQ-fcN-8D1C0b-K8LxOPkUeHiptoZXyM2GRvkXWs6cIfLZQf58C6j7CTGUqnLzo8GSzlMYfWd51Vw1Iey1jqTrLQ9TOGZ84sqkcxS4t9KVRhmSLw27-Ii-lTAKkV-h7hpKSwgWGsVm2g8FBCV_HEE1XKFsFWaRT-INMLLOaLgePlg4aorIG84mt2i2I7UuCnD9NETtmfT2CAH-zyD0EixAFwH3leo0iRypTghaZ-Pd4etR-y5w8eWPFFJtVCgZxzhsjm2xlHGhMFSnetN9gfp3DYMgwDo_b1XpyaCVZINqwIvfQGSuFhVuykvke82VrSK628y3sw_y5AanG-P2Z7g9cRjSJqLeQGgHCMG2cjtTZC1txKKOYNHnv_LKFokCmYqXCvIxB=w1215-h911-no
Cc-3iDkwczp2P9Bft6PK_bOiw5dxXD2i1aPuXy8TPSybzvP6mb1_QHwLKQMDVjAzqKFEotUF2lnDwomyvnTYeE1u4VUinJ9HmOsNMuiO9jfw4jtXJB37s7idjrBpTmvNJEcRb6-TkprWaYpT5tl6JIQBjnb82pArgiUOxMr3z_mPHRiyYzSMLMGUFhtcCtYVWNwFEfH7oeJVOlkaxQL3vZ0Eo6iTLsaa1LFXBwZ-rcozyuTsvWkg1A-dCWoSMCzwp5SfVi4-icts9UpvYjbNaMnRoMrmf8V_AjrFcr_AsjPYIq3h7TqpScQ9W96DZco2Wy-ecipaOWmUTmP6W6QHy4_JwDS_c21cs1YCY5Shiq__hbcELmBRdl-8TJlVZLcUbuAr97QA1y0JLfkv-Q8tqQSxrcWZbRC6QdCLjQkAPXIFgy3DVR5FVNyFgl9nDqEJh87CxuMvUaO_F2gFDIRu-wwq1APn-URPfE6ciNYaucfekQZ0gmintMthjd-SRwmEyfQ31yc5DmGlTwupeaTqa_ovMSJpEsfZ6q6xhzb5no-zZlxsh62Qrvlzjx8Nz-nyyi4i_CyMp0OYBj7UA0PLb1A-GtHeH3s4QO3uSMCw=w1215-h911-no
D11c_1e7QrL6sD_BIEEZcWWyg5RPO0Cbgdb0Izupaz7UXvIQfzqR1qzbZ-zf72LJXG4mUNZC18MpgctbodvRU3djrgmDk9_U1P43jGNi3rSiV0MWx4JAq0wBkGiM1dOoTmsI8_9SchYBcG38Ctz72n_5CkQFKa9spqEpyVog6m4HVAKAVPs2wldjuZCKne0BdOiuTk7VzAbjphCdXoghq6a3Pql4OVQsk6GL0luCJST5pglkHhSIntWReQqj4PVBIzzfdG-1met9jpNEoLa8JWMaK9FZnM0tW_-gZAixjhW55cymxISOxky4JzZT2ZmG3jdlnq7FgWh-XQ2wZu4DW8SBBmknk2wuPYGOdj0lpbgS2IL0SxZV1JdPAjmuobgSnGinOVUYPya6biZkXqJSJCcuxJluurST-MIk3bZtwoH2M73c3HjpCKtsd5oDpFraUNDbgSBlDvRFp2i2sF3OprjkoCEOcMi2EhWQDLaOyUjCD6AtuL2VvNEJ8z_MCqRQOOIQvMoaQUWKpT5mXS8p8AXlrM_mMLBlCSKqQhvauEm2VfrWp39G1gDYOE3IhdkaIQiEhoakAYk6x-QlfQ15LCeYIaL7581h3gvV_bkU=w1215-h911-no
I run a glass marine filter same location...does not seem to get too hot. Made world of difference for my trollholecarb which had debris sensitivity issues...a lot.
Well, I don’t know if the stock mechanical pump allows for bypass if the pressure gets too high (hence the return line on the factory carb). If it does not have a method of internal bypass it will continue to build pressure at the needle until it forces it open. Once the adjuster bends, then it’ll just keep pumping fuel until you shut the engine down.
You won’t have a regulator unless you or a PO installed one.
You can try putting in an inline return by putting a “T” in your fuel line with a restriction on the return side and see if that helps.
Good to know, thanks for getting back to me.
I was hoping that @Trollhole would chime in at some point but to my knowledge, many of these carbs have been installed without an in line regulator.
Do you think I should try one of these?
https://www.amazon.com/Mr-Gasket-9710-Fuel-Regulator/dp/B000BWAPQ6?tag=ihco-20
Bad reviews, maybe something similar w/ a gauge.
Better yet;
Black 160psi Adjustable Aluminum Fuel Pressure Regulator w/Oil Filled Gauge
What determines the line pressure is the spring inside the fuel pump. You can see part of it in the third photo in post #32. In action, the fuel pump lobe on the camshaft pushes the diaphragm down, pulling in fuel and loading the spring. The spring then forces the diaphragm up, pushing fuel on to the carb and returning the diaphragm to its at-rest position. When the bowl is full and the needle seats, fuel quits flowing and the diaphragm remains down. The actuating arm has nothing to press against, since the diaphragm isn’t seated, so it just moves up and down freely. There's no need for a bypass, since inline pressure never exceeds the spring load.
Dang great info, thanks! Does the spring ever wear out and the regulator stops working?
It may be nothing, but at least would be nice to know what the pressure is at the carb inlet.
I like your thinking. I am going to order a new fuel pump and get that installed so I have piece of mind and a spare for the future in case I need one. After I give that a go, I will see if I can get her running and then maybe pull the fuel filter by the carb and install a pressure gauge to see what it is coming in at.
This appears to be the correct one;
23100-61030 - Toyota Parts Deal
