Transmission Transfer Identity
Santa Fe, New Mexico
What might this mean? February '75 40
H42
Transfer
On transfer typically it is 5 year B month and then serial number/production number
75/February/0029th one made in February
The H at the end is a mystery as I think that has shown up before
@FJ40Jim is the master of the transfer case codes and afaik the code decifering originator
If I get time I’ll try to look into the mystery H
The side cover on the trans was used from 9/73 thru 4/75 or 1/76 IIRC, so even w/o a date code, there’s that reference.
Being a pre April ‘75, it’s going be a ‘transition case’ that you can drop the lower 3 speed case gears into if you are inclined.
