I have an 83 60. 4speed H42 with the 34mm idler shaft t-case
Got this put in today. Length was perfect. Quick question... do I have to be careful to assure the holes in the threaded bolt, align with the hose? That might be an issue. Hoping that there is still flow regardless of alignment.
12.75 inch hose on an 83 fj60
Alignment of the holes in the hose will be fine as there is a ring in the banjo fitting to allow flow. Just make sure bot to over tighten the bolts. If you torque them down like a bolt you will tear the oring. Its bot a crush washer. Snug is all you need so it doesnt leak.Got this put in today. Length was perfect. Quick question... do I have to be careful to assure the holes in the threaded bolt, align with the hose? That might be an issue. Hoping that there is still flow regardless of alignment.
Just wanted to show the bend around the bolt on the tcase cover plate. @shipmag asked to ensure the hose was not pinched or rubbing on the tcase. As it sits now there is a small gap, as the hose bends around the bolt. I suppose I could route it more like @CaptClose above, @CaptClose does your hose touch the tcase as it gets bent around?
Thanks!
No, mine does not touch. I've got a little over a finger's width of clearance.
Wouldn't it be better to order the longer one?Finally got my 12.75” hose on my stock trans/tcase 1984 FJ60. Length is perfect. Thanks, @shipmag
PM inboundI have two of the stainless braided hoses left at the old price. My vendor increased the price $0.50 per hose. The price will increase $0.50 per hose.
