Background:
'93 with A442F. Just got it running (see my other thread if interested in the engine build). It was purchased as a non-runner with blown HG. I have no prior experience with this particular tranny, but I daily drive another '93 so I know the A442F transmission from a driver's standpoint.
Facts:
1) 155,000mi, well-maintained vehicle by PO
2) fresh fluid (completely drained when engine and tranny removed), correct fluid level too
3) shift linkage adjusted and carefully readjusted as per FSM. All gears select as lever indicates.
4) Throttle cable adjusted as per spec.
5) feels, shifts and drives great in Drive and 2nd, but...
Issue:
When I select Low and begin from a stop transmission quite quickly shifts into 2nd. (Does not go beyond 2nd.) When decelerating and selecting Low it will not downshift until RPMs are very low - nearly at an idle/standstill. So, I cannot use Low for the purposes of locking in that gear (in high range at least).
A bit more:
Looking at FSM tranny troubleshooting, I disconnected the solenoid wire on the left side of the transmission and drove the vehicle. FSM indicates that means the tranny internals are sound.
Also, I briefly engaged the low range and with Drive selected Low held as is typical with a normal solid shift into second at speed/RPM.
Question:
what's wrong?
Thank you,
Scot
Facts:
Issue:
A bit more:
Question:
what's wrong?
Thank you,
Scot
