Transmission problems
Orlando,FL
Hi I have some problems whit my fj80 transmission I put on drive and go to 2 or 3 gear but manually from low up to drive works i check all the grounds trans computer relay neutral switch its new I'm looking for a valve body to buy or any suggestions what can be the problem,thanks.
Search NSS barrel connector. You mention the neutral switch is new. How was the other end of wires going to the connector? Corrosion in this connector will cause what you describe. Here's a thread:
1993 Transmission shift issues
