OMFG - any secret tricks for transmission pan removal?
This might sound really dumb to some of you pros out there but I'm reviving this old thread after doing searches on here and not really coming up with anything about the actual process of removing the pan. Everything says 'remove the pan' as if it just falls off after you remove the bolts and I've never had more trouble getting anything apart than I've had with this pan.
I removed it almost 2 years ago right after I bought my '93 80 because I wanted to check the pan for signs of damage because I was having a shifting issue and wanted to see of there were any chunks of metal in there... thankfully, there wasn't.
But MAN was it a giant PITA to remove it then when it had the orange Toyota FIPG on there... I fought with that thing for at least a couple of hours.. trying to cut around it with a razor blade... trying to stick a thin scraper in between there.. all while being afraid I was going to damage the aluminum flange surface .. whacking the living sh*t out of it with a rubber mallet FINALLY broke it loose...
When I put it back on, I used Black Permatex RTV and it hasn't leaked a drop, but now that I'm trying to remove the pan again the rubber mallet doesn't seem to be doing the trick this time.. maybe I just haven't hit it hard enough, enough times yet but this is very frustrating ... I'm wondering if the black RTV has just stayed flexible enough that it's just absorbing the hammer blows... worried I'm going to dent the pan... I've tried using a flat metal scraper again to pry around the edge but it's just bending and I'm still worried about gouging the aluminum flange... There's not a lot of room to work around that pan anyway.. I don't have the Toyota SST that the FSM shows being used to get the pan off and I thought about maybe cutting the metal scraper in half and then bending what's left to a 90 degree angle, thinking the shorter peice of metal will be stiffer and easier to wedge in there but still afraid of gouging the flange so I'm not sure this is a good idea... I was wondering if anybody out there has some special trick for removing this pan without it taking all day.
Once I get it off this time, I'm hoping I won't have to deal the sealant mess again because I bought the NAPA kit with the, according to their website, neoprene gasket.. it seems thin but hopefully it will do the job because I don't want to use any sealant on this pan again if I can help it.. the NAPA instructions say not to use any adhesive or sealant with this gasket. Has anyone used one of these gaskets before and has it leaked at all?
BTW, the only reason I'm removing the pan again is that my shifting issue has returned and I've decided to replace the transmission solenoids in hopes that it will finally be fixed.
