I fired up the new '75 engine to make sure there were no leaks and to make sure it ran ok.The truck only has a frame,dash,engine,transmission,transfer case and axles.The drive shafts are off right now.I checked the tranfer case to make sure it was working and checked the transmission.I put it in 4th gear and let it run and took it up to about 40 mph.I noticed some noise in the trans.like a banging(not loud).It sounded like something was off center.Could that be from running it without the driveshafts?It shifts fine and and clutch works with no problems.Flywheel,clutch and pressure plate are all new.Any ideas? Thanks!
