Transmission mount orientation
Anchorage, AK
Which end is supposed to face forward? In the middle you can see a little “bump” on one side. 2H/H55
I am asking about the for/aft orientation 🙂 which way does this nub face? Thanks
The studs to the cross member in the isolator are not centered between the holes for the bolts to the transmission housing. Because of this, you can't get it wrong. i.e., the holes will not line up.
What has worked for me as a quick check, is locate the isolator on the cross member then hold the cross member in place and visually check the transmission bolt holes. If they align, I got it right and finish the install. If I got it wrong, reverse the isolator on the cross member (here the tab faces the opposite direction) and repeat.
Looking myself to reinstall my setup and forgot to take a picture (been a couple year ago). How did you install your transmission mount under your 75?
The small tab faces the front of the vehicle.
