Transmission identification
Canada
Looking to confirm this is a H42 transmission, as for the transfer case I don't know. Reason is the shifter is about 1" to long to seat itself properly so I need to order a new one. Cheers
The length of the fine splined input shaft would mean it’s a 4-speed that was mated to B-diesel. That transmission top plate should not have bolts where the shift cane seats. There should be guide dowels there. Maybe the bolts were a “fix” that prevents the cane from fully seating.
That looks like a four speed from a FJ60. If a US import would be a H42. Any H42 shifter from H41/H42 should work. The three speed the end tie shift cane was longer. All these are H41/H42/H55F shift canes. The only difference in the H55F than the four speeds is tip is a round ball verses flat side. All are the same length.
That again makes sense since I the previous owner was part way through a conversion to a diesel. So likely had a 3spd in the 73 Fj40 and the proper shifter never made it to me
If you look at the hoarder’s, I mean @Living in the Past ’s stash of shift canes (just kidding, I’m just jealous of your rare parts stash). There’s a groove on each side of the shifter seat for those guides (bolts in your case).
I show about 3-1/2" if shaft below the ball
Yes, just can't get it in deep enough (first time and last time I will say that)
Ok, thought that was the issue of miss matched parts. Sadly previous owner died 25 years ago and I just got boxes of parts for gas and diesel. So I will source the proper shifter, sadly in Canada not so easy
A shift cane for a four speed should be easy to find. If your putting this in a 40 series with a stock engine it will need to be bent up since this a for a 60 or 70 series.
Lot of pros only con I can think is does not have a hand brake. 8/80+ all 40 series except the long wheel base had a hand brake on the rear axle. Parts are available to add a hand brake. Flanges changes over the years and driveshaft lengths mat need to be modified.
Drive shafts definitely are not correct since it had a gas 6 originally and it is being converted to a B3 with this transmission so it doesn't bother me. And yes I did get the drive shaft ebrake with the parts
