Ive had a leak for a while now and Im trying to locate the problem.
I have the Advanced Adapter between the NV4500(cummins) and the 60 series split case, the thing has been leaking more and more for the past couple months and I really need to get to the bottom of it.
My trans is just about out of fluid. There is oil on top of the transmission and the split case is soaked and dripping.
The split case is soaked but has plenty of fluid in it, the breather on it is also pretty much clean and not leaking.
The top of the transmission is oily around the top and near the breather, but there is no noticable source for the leakage.
Im thinking I either am somehow blowing oil out of the breather on the trans, or am pushing oil to the t-case and then its seeping.
At around $30/litre of the special transmission fluid for the NV4500 (uses about 4 litres and must be made of koala tears for the cost) filling it up every now and then is not really an option, driving it without fluid probably isnt either.
I've separated the transmission from the motor a few times too many in the past, and the t-case from the trans to try and solve a slowly developing leak (by using heaps of gasket maker in between everything) which seemed to make it go away, but loathe the idea of doing it again and not really knowing the source.
Any thoughts on an upgraded breather to avoid possible leakage? I kinda got a feeling it is just pushing the fluid forward to the split case, and for what I payed for the adaptor (about $1K CAD to the door) Im gonna be on the phone with AA to tell them how I feel if that is the case. (I wonder if I could put dye in the trans fluid to see if it migrates to the t-case? Also, any thoughts on clear tubing and two ports on the t-case to check fluid levels?
Any help or distraction much appreciated.
