Transmission fluid
Jefferson City TN
So just picked up my cruising from getting lighting setup and drove it about an hour home.
Transmission shifts fine, smooth and good.
When I got off the interstate I noticed a funny smell(think garbage burning smell) I drove to the closest gas station and checked the transmission fluid level. It was hot and showed a little low on the dipstick for hot but wasn't off the dipstick.
I did notice my axle breather tube was off and I couldn't tell if that was the garbage smell. Anyone else had this experience? I assume that a little low after a 1 hour interstate drive is fairy normal. This trash smell showed up after the lift so I am guessing it is the breather tube, but want to confirm it and the transmission level.
94 80 series.
Two different smells. ATF has a, well, fresh smell, almost sweet smelling. Burnt ATF is not red and has a burnt smell. Gear oil, from your diff, is stinky stuff... period. That's my suspicion with the modest info provided. My front axle breather was giving me an attitude too so I replaced the hose and ran it up to terminate near the battery box. It has a little screen filter to keep stuff out, but otherwise breathes freely. It's been a good mod for me. You'll see a bunch of fancy relocation posts searching this forum.
Thanks,
I am aware of the different smells of both fluids. I agree that the smell was probably hot diff fluid since the breather hose was off. I was more concerned about the fluid level after a long drive. Going to warm the truck this morning and run through the gears then check the level. I was more curious if showing a little low after interstate driving was fairly normal.
Sounds a little low to me but not by very much. Worth repeating the test. When you warm it up today or next time make sure it's to full temp like your previous test (1/2 Hr drive) but run it through the gears before checking like you mentioned
What's "a little low" Was it down to the cold marks?
Once your on the dipstick it doesn't take much to make a level change. I was a little over full so pumped out a quart and was on the low line when hot. 1/4 qt brought me back up to the right spot.
If your truck has been up on a lift recently ive seen the breathers pop off from the droop of the axle
It was down on the cold mark after the drive. Going to drive it to work this morning and then check it. My guess is you are correct. I am probably just a little low. But I had read on here when searching that after a hwy drive it may show low when in fact it was not. Will report back what I find
I think used ATF smells like bad BO, that could be the trash smell you describe. Gear oil doesn't smell that bad, just a stronger smelling engine oil. As for the trans level, you want to check it warm but not after a hard drive. I think highway is usually easy depending on your RPMs though.
Transmission was about 1.5quarts low. Smell never showed up today, but I didn't hit the HWY at all.
