Transmission fluid
Orlando, Fl
i know this is gonna sound dumb, how would i change the transmission fluid, and what should i put in it, and do you think it could be old tranny fluid making my trannyhump hot after highway travvel?
get about 6 quarts of 90w oil. You should replace the tranny and t-case oil at the same time. You need to take off the skid plate underneath and you should have access to the drain and fill plugs there. Do a search here to find pictures if you do not have any of the manuals.
Most people will recommend an oil pump for this.
pull skid
align drain pan
pull FILL plugs (you'll be pissed if you drain and these don't come loose)
stick finger in each, see if the level is close or not - if one/the other drools out the fill, you have a seal problem
pull drain plugs next
go inside, surf chitchat for about 30 minutes...
85W-90 gear lube, I used 5 gallon pails and a nice metal lid-fitting pump
replace drain plugs
pump with lube until it drools out the fill hole
replace fill plugs quickly, a tad overfull hurts nothing
catch up on the chitchat threads you missed....
well, since none of my car friends have a truck without a tranny fill spout in the engine compartment, none of them have an oil/fluid pump handy, where should iget one?
