Transmission Fluid
I recently switched out my radiator and lost some transmission fluid in the process. I'd like to top it off- question is, what should I use? On my Volvo's and Benz's the fluid is very particular.
Whats the appropriate fluid?
I use Valvoline MaxLife in most of my vehicles, it claims to meet many specs. I prefer not to have 3 different types of ATF lying around if I can avoid it.
Any Dex III or higher spec ATF will be fine. As mentioned above, I use the Valvoline maxlife. Before that I used Chevron DEX III ATF. It all worked fine.
I think I'm sing some Dex/Merc stuff that says it's compatible with Dex 3 and 4.
My bigger issue is trying to read the dipstick level accurately o_O
Thanks- I'd love to do a complete fluid change but have too many pressing projects. I actually have some Dex III in the garage from a P/S job I did a while back.
