Transmission Fluid Question
Santa Monica, CA
I apologize if this has been asked before, I searched for a similar thread but I was unable to find an answer.
I own a 94' FZJ80, it's been in my family since 1996. It has around 185,500 miles on it and the automatic transmission fluid has never been changed. I was wondering what the overall consensus was for changing the fluid if it has never been changed before. I have heard before that if it has never been changed then it never should be changed as the gunk adheres to the gaskets and can break the seal, but that seems a little ridiculous to me and doesn't sound even remotely right.
The truck is running great and I have no issues with the transmission other than a stretched throttle cable causing the shifting to be a little odd occasionally. The fluid isn't pristine pink, but it's only very slightly reddish/brown. The 35'' tires work great with the tranny as far as I can tell.
When I check the levels when hot the dip stick reads halfway between the cold notches, yet when I read it cold it reads halfway between the hot notches, so that is rather odd.
I've read that it's a fairly easy procedure and that I should obtain OEM fluid if possible.
What's the general consensus, should the fluid be changed at this point or should I just leave it alone seeing as the truck is running great?
Thanks for your time.
mud members are not the best ones to ask about fluid changes on these cars. We all suffer from a variety of psychological disorders, including anal retentive disorder, obsessive compulsive behavior, frequent fluid change disorder, OEM parts disorder, etc.
You will see members here change the ATF with every engine oil change (3000-5000 miles).
If you look at your car and think how many miles the ATF was in there and look back at what I said, you can see how contagious mud can be.
I've had many cars before with no ATF changes at all. I don't know anyone outside this community changing the ATF more than once in the lifetime of their car.
I can't find the print in the Toyota manual about ATF changes. Maybe a flipped a few pages at once.
Most car manufacturers now say the tranny is sealed for life.
If you stick around here, I can guarantee you will perform ATF changes once a year. Good luck with your future disease.
I've had many core before with no ATF changes at all. I don't know anyone outside this community changing the ATF more than once in the lifetime of their car.
The only reason i want to change it is because it is reading low on the dipstick and I dont know what the previous fluid was. Do you think its better to just top it off or replace it? Its running just fine at this point. No slipping or any other issues. Thanks.
Very right definition of mud tribe. Hahaha.
Enviado desde mi SM-N910H mediante Tapatalk
Here is what I do and it has proven neither advantageous, nor have I ever had a Toyota Tranny Fail. Several new Lexus Vehicles have sealed transmissions with no drain or fill port.
1 Gallon Full Synthetic Fluid from China*Mart.
  • When doing a motor oil change unhook the top Right Transmission Cooler line going into the Radiator. Removing the grill can help get the clamp.
  • Hold line in a bucket (some extend the line).
  • Start the truck and let it pump the tranny fluid out till fluid stream ends, then shut truck off.
  • Refilll with the same amount removed using lines on container to judge amount
  • This changes fluid thru dilution, as torque converter can not be easily drained/filled
  • This method if careful makes zero mess. I think running about 3 gallons after oil changes should get to mostly clean fluid.
**Recycle Tranny Fluid with used motor oil using the old oil containers from Tranny, Windshield Fluid, and Motor Oil. Drop the jugs at the Parts store and tell them to recycle the container. It's a good feeling when you make no waste.
The filter can be changed, but it is like window screen so it only catches large particles. You will need more gasket caulk (FIPG). I'd go with Toyota brand since its under $20.
Amazon.com: Genuine Toyota Fluid 00295-00103 Formed-in-Place Oil Pan Gasket - 3 oz. Tube: Automotive
Compare new fluid to old and also compare the smell, so you edgucated for next time.
Thank you. I will try this route.
At that high mileage I would change it completely. But 5000 miles intervals is just nuts.
For the last two years I did 4 oil changes, and with that, I drained the tranny from the plug and replenished what was taken out.
I think I'm done dealing with it now. I can rest my case.
I plan to do this soon. Picked up 20 litres of some house brand synthetic Dexron III fluid. I have owned the truck for almost 2 years and the previous owner did take good care of it but the way I treat it I want to make sure it is good. Every mile I have put on the truck has been hard use so I think it is time well spent. Installing tcase gears and 5.29's so I am changing lots of fluid anyways!
Hey guys,
I am new to the cruiser world. Recently i picked up a 1992 FJ80. Truck is great, but it has some leaks. First one i am trying to tackle is from the trans pan. The information here is great. I am just wondering do i need the "Toyota Gasket Maker" stuff as quoted in the post above? I assume this is very similar to the popular "Honda Bond".
I plan on using this for my trans filter which comes with a new pan gasket:
More Information for WIX 58973
So i am not sure if i need the toyota gasket maker in conjunction with this, or can i just use the gasket alone?
thanks very much in advance
Hey guys,
Permatex Black (High Temp) should be a fine substitute.
Follow the directions word for word.
Make sure mating surfaces are perfectly clean and wipe them with paint thinner or Zylene or similar.
@Hornd thank you very much for the response! Your info is really good. So in addition to the gasket i get in the kit, also apply the permatex. Similar to most oil pan applications. Thanks again.
