Pull the trans plug
Measure the amount drained~3.25 - 3.5 US quarts
Reinstall the trans plug
Use a small funnel and refill through the dip stick
Check level
Check level hot, drive around for 20 min or more. Our transmissions tend to take a while to warm up.
19 lbs might be a bit high, we usually replace the drain plugs and chase the threads, then torque to 14 lbs. with a new crush washer.
I appreciate the feedback. Any better trans fluid than oem?
Alleycats said:19 ft/lbs. is what my FSM calls out on the trans. drain plug FWIW.
Keep in mind that 4 quarts isn't nearly the amount of total fluid in your tranny. Many do a drain and fill a couple times a year which keeps fairly new fluid flowing.
On our '93, draining the pan nets 5.1-5.5 liters... so I prefer to have 6 quarts of fresh fluid on hand.
