Transmission drain bolt gasket part#or size
East Brunswick, New Jersey
Need some help to find tansmission drain plug gasket/crush wahser part number or size. Tried FSM,amazonebay and searched the forum but no luck finding it. As I did not know how many times mine has been reused,I would like to get a new one. Thanks for the help.
Steel crush gasket, same as on the axles (but not the transfer case, those are aluminum)
12157-10010
Very cheap.. so get a handful and you'll have spares for a long time
Thanks a lot. It is the same as rear differential as I bought the other day. See below:
GENUINE TOYOTA GASKET KIT
12157-10010 TAKES QTY 3 TWO FOR REAR DIFFERENTIAL AND 1 FOR FRONT DIFFERENTIAL
90430-24003 TAKES QTY 1 FOR FRONT DIFFERENTIAL
90430-A0003 TAKES QTY 2 TRANSFER CASE
