Transmission drain and refill question.
Minnesota
The FAQ and sticky calls for 11.6 us qts of ATF. But that seems a lot.
Is this number for a dry fill or drain and refill?
very good to know. maybe someone should edit/add the faq section.
Sorry to dig this old thread. But I am trying to learn that if there is any simple or easy way to drain all the atf from the gear ?
My vehicle takes 12L ATF Dexron-III or T-IV.
But from the drain bolt, it only drains ~6L.
I want to change the whole 12L ATF at once.
thanks in advance.
thanks in advance.
There is a thread and maybe even a video of how to get all the fluid out. It involves taking off one of your transmission cooler lines and putting the line into a bucket and starting the motor to pump out the old fluid. Just make sure you keep fluid in your transmission pan and don't let it run dry.
These guys flushed the ATF from the oil cooler:
thank you. it helped.
i checked but i couldn't find the atf cooler lines in the engine bay.
i guess better to take it to workshop, show them this video and ask them to do the complete flush.
thank you once again for your help.
