transfer rear output seal
I found a drip on my rear transfer case out put seal. When I topped it off it took 14 oz. My records show that I filled it with mobile 1 full synthetic 25,xxxx miles ago. If it lost that much in 25,000 then I will just keep topping it off for the next few months. But I will check it again I'm a few weeks and see.
Regardless I will replace the seal this fall/ winter when I rebuild my drive shafts. Once the drive shafts are out how hard is the transfer case rear output seal? Any thing else I should do "while I am in there"?
Need to get the correct lock ring pliers. The straight ones are the ones which I find the most helpful. EBay item 131122414611 is what I bought.
My suggestion is to take off rear extension housing and do only what is needed. Have the seal ready, if bearing is chunky, replace that as well.
