transfer case seal
Houston
'94 auto, AWD. (typical NA powertrain)
Leaking gear oil between the transfer case and transmission which I assume is from the input shaft seal of the case. Is the tranny rear output seal replaceable at the same time? Any other items that I can do while I am in that part of the operation?
well, if you're going to drop the Tcase, you might as well re-seal up the entire unit, along with front and rear output shaft seals!
