Transfer Case Question
i have a 91 i bought 3 years ago its an awd model with the center dif. switch,auto trans.1 of the 1st things i did was replace all u joints to get rid of the loud clank when putting it in gear.well it turns out its front wheel drive and the center dif engages the rear,i had to run up to the store without the front drive shaft it wouldnt move until i hit the center dif switch,(ran much smoother)my question is,is this correct its not really awd its front then rear? and also it wasnt my u joints its the transfer case anybody ever rebuild one and whats the typical parts involved,source and cost?any help will be greatly appreciated.
the clunk it's normal for all auto Toy trannys .. well all in 80 series means A440 and A552 .. yours it's a A440 with a HF2A t-case ..
its worse already,vibrates bad in the 30 mph range and up and it has a steady clicking sound as the vehical is moving.thanks for the info.
btw,is there a way to make it constanly power the rear wheels instead of the front and then engage the front with the cdl switch instead of the constant front wheel drive?
Uhhh...No. That's not how it works. You have full time 4WD with a center differential. When you removed a driveshaft, that end of the differential was spinning like mad because it had no load. Exactly the same as lifting a tire on an open diff axle. When you lock the center the truck moved because both output shafts of the center diff were locked together (no differentiation).
Have a look at this link:
Welcome to Land Cruiser Owners On Line
i understand the theory but since it was spinning like mad shouldnt it of transfered power to the back anyway kinda like if the wheels were spinning in mud?if it were a true awd it wouldnt need a cdl it would transfer automaticly.
What you're describing are limited slip devices which your truck does not have. You have 3 open differentials, with the ability to lock the center one.
I pointed you to a good link that decribes how things work. Have a read.
AWD is a vague marketing term, which generally refers to car based platforms that generally do not have a 2 range transfercase. AWD can refer to several different means of connecting the two axles, some do not have true center differential, just an electronically controlled clutch pack that engages when the normal drive axle slips.
Land Cruisers technically have Full Time 4x4, meaning the transfercase always sends power to both the front and rear axles via a center differential.
91-92 have an OPEN center differential. It sends power to the path of least resistance. That is why the truck has a Center Diff Lock switch.
In theory, with all three differentials unlocked (front, center, rear), only one tire has to spin, the other three would not.
93-97 have a viscous coupling tied to the center differential which in theory should act a mild limited slip.
Limited slip differentials generally can only bias torque, like a 3:1 ratio. Meaning if a wheel is sliping and only providing 20 ft-lbs of resistance, a 3:1 bias limited slip could send 60 ft-lbs to the wheel with greater traction. If one wheel (or side) has zero resistance (i.e. in the air) then most limited slips will not work (3 times 0 is still 0). The trick in this situation is to apply the brakes so the side with 0 resistence now has some torque to bias. I do not know what kind of bias ratio the viscous coupling in the center differential has.
So with a drive shaft removed, the center differential must be locked to move the vehicle. There is nothing wrong with your Cruiser if it does not move with the center differential unlocked and one driveshaft removed.
:cheers: and Happy New Year!
thanks dudes and happy new year too.just seemed odd to me.any source for parts?anyone ever open one up?is it all gear to gear or is there a chain and sprockets that may of strecthed out?just want to get in it b4 any serious damage occurs.
