If you don't have the longer spacer just use the pto gear. No reason to look for the longer spacer if you do not have one already.
There can't be a leakage issue because the new tcase doesen't have a hole and oil sloshing around in the spacer is not a big deal. Does the spacer you have isolate the two sections between the web? Or is the web only at the tcase side. Post a pic of the spacer if you can.
Tony
Tony
