Today on a whip I was crawling around under my pig looking at the exhaust. I noticed a loose plate... Looks like the bottom of the transfer case or the trans. A few bolts missing, and I could see gears thru the gap...
and no gear oil leaking out huh?oo ooand no gear oil leaking out huh?
So, of course, you slapped a little rtv up there and bolted it closed and added some gear oil?
That's just the cover on the bottom of the bell housing. Replace the missing bolts, tighten up the others and call it good
Don't I need to fill it back up... where's the inlet bolt?
Since the gasket is no longer available, I used some 1/2" wide double-sided foam insulation (about 1/8" thick) to make a new seal. Seems to be working pretty well.
