Trans Swap Questions
NorCal
The 'new' 3-speed t-case is really whiney. MustardFJ40, from whom I bought the case, said it has all new gears. Surprising? Did I put in too many thrust washers on the rear output? I didn't measure it with a spring scale, but it doesn't feel tight at all. I took out two thrust washers and put two back in. I didn't use a torque wrench either. :eek:
The new pilot bearing caused a bit of a scare. It drags when new, so it feels like the clutch is still partially engaged. I figured it out pretty quickly, and it's already getting better. Normal?
The 2-low mod is awesome! I use it all the time. It's great to have two reverse gears.
I'm holding off posting my impression of the h41 until I spend some more time with it. So far we drove it mostly off-road, where it's great. We'll see how I like it for grocery getting. It's not low enough to start in 2nd, but I found I often roll stops without dropping down to first.
Ed, if you can move the parking brake drum up and down by pushing on the driveshaft, it's DEFINITELY TOO LOOOSE!:eek:
If it doesn't move, that's prolly not YOUR problem.
Next question. Did the imput transition gear from the 4 speed to the 4 speed case come out of the same transfer case? Kinda doubt it, as that imput wouldn't have been matched from the factory with the early idler gear. Sooooo, there's a fairly good chance that those two gears are mismatched, and that THAT is the source of your whine.
I know my 3 speed transfer was really nice and quite until 3 weeks ago, when I installed my 4 speed with a brand new transition gear. I don't think it's my 'new' tranny that's whining either.:frown:
Hth
Mark A.
Ed, if you can move the parking brake drum up and down by pushing on the driveshaft, it's DEFINITELY TOO LOOOSE!:eek: [/quote[]
Nope. It's not loose in any way.
65swb45 said:
Next question. Did the input transition gear from the 4 speed to the 4 speed case come out of the same transfer case? Kinda doubt it, as that imput wouldn't have been matched from the factory with the early idler gear. Sooooo, there's a fairly good chance that those two gears are mismatched, and that THAT is the source of your whine.
Not matched. If you're saying the whine is expected, that's it. They're fresh for each other. It's a 3-speed case, matched to the h41 4 speed that I bought from you.
If it's expected, I guess I kinda like it. It reminds me of the m22 in my old 'vette. It's noisier than my swampers in most cases.
