Tranny wont shift when cold!
Notice that I mentioned a REPLACEMENT tranny; I have yet to find anyone who can rebuild a tranny that will last more than 50K miles; might as well order a new one from CDAN with a deep discount and be done with it; that is, if you plan on driving your 80 for a few more years/100K+.
Whoa now.
Agreed that a "local" rebuild on an 80 series tranny (of which there are three) is very likely to be a waste of money.
On the other hand, a rebuild from Rodney at Wholesale Automatic Transmissions is a proven lifetime replacement/cure for a failed 80 series tranny.
Curtis
Whoa now.
Curtis
Well, if we are talking about Australia, that is another story;
They are probably the only people in the world that can not only properly rebuild an A440 or A442, etc; but they can also improve on the original design and performance; only thing is that they are on the other side of the planet.
Slee stocked those trannies for a short time, but not now;
don't know; is anyone stocking them in the US anymore?
I personally would love to get one of Rodneys trannys; I need an A440F for my 62 which is bleeding in my garage.
g
That was a strange thread. Wondered how I missed it as well until I realized it was not an 80 thread.
DougM
Slee stocked those trannies for a short time, but not now;don't know; is anyone stocking them in the US anymore?
The marketing arrangement with Slee simply didn't work out.
Call/email Rodney directly. Folks in the US buy from him direct all the time.
Curtis
Yea, I've been following the thread on the 3FE list regarding real world end user costs for this. Seems the transmission itself is the cheapest part of the transaction.
Some years ago on the old 80 Series COOL list, there was a thread about rebuilders on both US coasts that were working with Safari to tune A343Fs with good results. George Couyant was working at Safari at the time and reccommneded them. Gotta search the old archives for that one.
Could be that the govenor valves and/or the valve bodys valves are sticking until they warm up, but with the manual shift into 2nd I can't see the VB being the problem. like gray said, try some LUCAS Transmission additive to break up the sticky valves.
Glad to hear the "no cold shift" is normal. I was getting concerned. On my morning commute, it'll consistently shift into OD within about a hundred yards of the same spot about a mile and a half from my driveway.
I should restate what I said from my previous post so no one gets the wrong idea;
I don't think that Azzukki should use LUCAS as the first thing; he should check the fluid level, smell it and look at it to see if it looks burnt or is full of crud. ie: look at the fluid on the dipstick under full bright sunlight with the stick a few inches from your eyes to look for particles, metal flakes,etc..
If he hasn't flushed it, ever, and doesn't know what type of ATF or additives are in it, then he should do a complete fluid flush. I use LUBEGARD (not LUCAS) for a tranny cleaner; no solvents to hurt anything. Then a flush with at least 14-16 quarts of a high quality fresh ATF; not the cheap bulk stuff at Quickie Lube (unless you are going to do multiple flushes, read on)
If the fluid is really filthy then he could drop the pan first and clean it out; this is a point of controversy; I have done it both ways; ie: flush a few times, first with cheap crap, then the final fluid flush with Mobil 1 synthetic ATF as my final fill. Or, you can drop the pan, clean it out, pull down the screen filter, carefully clean that, put it back with a new gasket for the filter and the pan. Then flush it, etc. His choice.
IME experience, unless someone has dicked with the kick-down cable, his problem is most likely due to internal wear, unless the fluid is totally screwed up, wrong, burnt, etc. You can adjust the kickdown cable to get more pressure into the valve body, but that only works to a point, IME. There was a TSB on the A440F like 20 years ago; something to do with replacing the check balls in the valve body, don't recall the details though; the replacement check balls are made out of a harder material I think.
If after all the checks and cleaning and flushing with new fluid, he still has a problem, and does not want to spend the big bucks for a new or rebuilt tranny, he could then try any of the viscosity improvers (like Lucas tranny fix) as a last ditch effort to get some more miles out of it, before he, or someone else, would have to dig into it.
I am not a fan of tranny additives; they are not helpful in a properly functioning tranny and usually hurt performance, IME. Just gotta start with a good quality Dexron ATF.
G
Yes, with your year the delay to go into OD is due to the cold temp;
once the temp needle moves about 1/4 toward center, it will shift; I don't recall the temperature it needs to get to before the ECM will allow the tranny to shift into OD and lock-up (someone on the forum knows). Same with my 96 model, about 1-1 1/2 miles before it will shift into OD first thing in the morning. No delay, of course, if the vehicle is already warmed up.
g
Give your rig an extra few minutes to warm up. Don't just start it, wait 10 seconds and drive. Give it 2 minutes to get the juices loose, then start off real slow, so you don't have to shift out of first for a couple seconds.
Does it do it now that it's getting cold out, or does it do it even in the summer?
Now that we're talking transmissions, I've got a question:
Sometimes when I shift from park to drive, it feels like I'm in 4L. When I press on the gas, the RPMs go up to about 2k with minimal pressure, and I barely accelerate.
I remedy this by taking it out of drive into neutral, and then back into drive. Then it accelerates like normal.
What could be the reason(s) for this, and how easy is it to fix?
tomatopants;
Haven't heard that one before; wondering if your linkage is set-up correctly though. Either way, something not happening correctly in the valve body would be my first guess; as you read through the threads on this you will see references to a few fixes that have come out over the years. If you haven't done it yet, I would do the complete clean, flush and fill with a high quality Dexron type ATF. Many quick lube places use a Multivehicle ATF and may add an additive to bring the ATF up to whatever spec they are aiming for; you want to avoid those guys. If complete cleaning and flushing doesn't help, you can try a viscosity improver like LUCAS tranny fix. After that, it's time for the stealership.
g
I took it to a mechanic who did the whole deal, including removing the pan and putting in a new gasket, about 10k miles ago. I'm not sure what brand, but I know he used a Dexron type ATF.
I check all my fluids frequently, and it's in between the 2 lines it's supposed to be when it's hot, but I might just end up unscrewing the drain plug and fill it up with a quality fluid, and then my next oil change do it again. Cycle out some of the stuff that's in there, even though it's the same color now as it was when it went in.
While we are on the subject of transmissions, I have a question. Do the 90 FJ62's have the same trans as the 91 FJ80? My brother's 62 is really bad on this cold get'r going mess, and I have a spare for a 91. Maybe the tail shaft is different to mate to a different transfer? Anyone know?
Hope it's ok to tag this on. If I need to start a new thread just let me know.
TX, For the most part the tranny's are the same, however IIRC the tail shaft is different. I have three fj62 trannys and 1 FJ80 tranny at the house and the shafts look very different.
Heres the 80 output shaft.HERE
The 62 is longer and has a thread at the end.
With the tranny working very well when warm im pretty sure its nothing but a dirty filter.
so when i get time i will dump all the fluid and change the filter and add new fluid.
I think what happend was wile wheelin on "Smasher Canyon" a few weeks ago , i think i must have stired all the "poop" up and cloged the filter.Ill keep ya all posted on the fix of the 91 cruiser tranny.
Rob
It is pretty hard to clog these filters; they are a metal mesh screen (not paper like most vehicles);
be very gentle/careful cleaning it; easy to mess up the sieve.
Good luck
g
