Tranny wont shift when cold!
FLagstaff Az. Elv.7000ft
My tranny just started having this problem.
It wont shift when cold, i can do it manualy.
But when its warm it works fine????WTF..any ideas?
Thanks
Rob
Ps: the fluid was changed a few mounths ago, its claen and has no oder.
Uhh... Rob??
"Won't shift when cold", huh? That's it? Not exactly a precise description of what's going on.
Oh, and it'd be nice to know which rig we're talking about as well...;p
Curtis
Its the 91 80, what i mean is i start down the street and it just stays in 1st and wont shift til i put it in 2nd manualy.
Then it will go to 2nd but when i go to third it just revs till the rpms get over 4000 then it will shift to third and 4th.
then wehn i get to the next light , i have to do it all over again.
but by the third light the truck is warm and the truck shifts normaly again.
Try a computer reset. Disconnect the battery for about 10 minutes and re-connect. This is where I always start when things act up. (With the exception of check-engine lights), then I read the code first.
If that doesn't work, check the fluid level and flush and fill, if necessary it hasn't been done lately.
If the flush and fill doesn't work, Then drop the pan and change the filter. I think the filter kits are about $40 including gasket.
Keep it simple, don't worry, the transmission are considered relatively bullet proof.
sometimes on 1993-1997 FZJ 80's they wont shift into OD until the engines reaches operating temperature. This is for emissions. It does this so the engine will reach running temperature and operate with in the designated operating range.
on 91-92 FJ80's I don't think they had this emissions setting since they are OBD I. I would suggest checking the tranny fluid level while it's cold, then checking it again once it's warm to see if you're not simple having issues due to low fluid. Check it while the vehicle is running. It might simple be a matter of expansion once it gets hot enough.
i might be wrong on this so correct me if I am.
Did YOU personally change the fluid?
And (as others are saying) have you checked the level using the exact procedure in the Owner's Manual and/or FSM?
Next step for me would be inspection/adjustment of the "kickdown" cable.
Curtis
No electronics in a 91-92 tranny.
Non-electronically controlled transmissions can get mixed messages from the power output of the engine also. If the transmission is not sensing enough power or speed to shift, they can get hung up.
If there is a computer involved anywhere in the drivedrain, a reset is one of the cheapest places to start.
I should have done this when I had the tranny 'power-flushed' recently with the BG flush service. Would have been easy enough to do, I just didn't plan on a full flush so didn't bother looking at the FSM.
But my tranny sure shifts nice, so I can't complain!
Listen to Curtis. There are no electronics in the A440F. Shifts are determined by internal fluid pressure in the valve body and by throttle position. Certainly check the kickdown cable first, but even if the cable was broken I believe it would still go through the gears. The fact that it shifts properly when warm sure sounds like sticky valves 2 me.
Drop the pan, replace the filter, fill up with decent ATF and see what you have. Remember to clean all the poop on the bottom of the pan.
BTW, did this start happening soon after the tranny fluid was changed??
No , but it did start after the first realy hard wheelin trip.....
Im wandering if the wheelin trip stired all the "poop" in the tranny up????
:confused:
I'd like to see that
Wow.
That is one weird thread. I must have been out of town for that one...
Seriously. I love the guy that said a transmission will not shift at all until the temperature comes up. I think he has a problem with his transmission ;)
Ditto; all the routine checks; fluid burnt, fluid level, proper fluid, adjustments, etc,etc. Sounds like loss of internal pressure; ie: not enough pressure building up to allow shifts. Can't ignore the history; ie: that it started right after wheeling which means high heat which can ruin the fluid in a few hours, burn up the disks, damage internal seals, etc, etc.
Storytime:
Had an old Oldsmobile that would not shift out of first, first thing in the morning when outside temps where much below 70 degrees. After a mile or two, it would then start shifting OK. If it was like 30 degrees outside temp in the morning it would not move, so, I would start the vehicle, then go back in the house to have breakfast, shower, etc; 20 minutes later, it shifted perfectly. As it was a DD and POS worth less than zero I just continued to drive it in that condition; for 6 years and over 120K miles.
g
Same problem I've had with several vehicles with over 200k. I put a quart of Lucas Transmission non-slip in it and problem fixed. The Lucas additive is thick as molasses and helps in increasing the pressure to allow the shifts. Not a snake oil advocate, but this stuff works, just open the top let it drain through the fill tube overnight, should be good to go.
Agree with trying to diagnosing the problem first as all above, flushing the tranny completely with the proper fluid, etc; but if everything else fails, and you don't have few thousand laying around for a replacement tranny, then the LUCAS Transmission additive is worth a try and often works; that is exactly what kept my old Oldsmobile on the road for so long.
Notice that I mentioned a REPLACEMENT tranny; I have yet to find anyone who can rebuild a tranny that will last more than 50K miles; might as well order a new one from CDAN with a deep discount and be done with it; that is, if you plan on driving your 80 for a few more years/100K+.
G
