Trailer Wiring
Sandpoint, ID
I can't seem to get my right turn signal to work on a trailer that is attached to my current trailer wiring harness. I figured it would just be a plug and play type of a replacement, but after looking underneath there, I'm not so sure that's the case. I've attached some pictures to show what I'm talking about. Can you guys point me in the direction of what I might need please?
I had this same problem a few weeks ago. You will need a new wiring harness. I bought a Hoppy, but there are others out there that will work. You need to open the rear passenger panel under the window and that will give you access to the box that your wires run to. You should just be able to pull it out and put the new one in its place and rerun the wires. Newer 80s are plug and play. Mine (a 94) required some wire splicing, but once you know what each wire does, it isn't that hard. There are several threads that go over the process and tell you what each color wire does if you need that. I'll try to see if I've got a link or two that I can find to help you.
Apparently U-haul sells a harness that plugs into the wiring harness connectors, no need to cut into any wires.
So far I have come across 3 different brands/styles of "trailer wiring adapter boxes" in the right rear fender on 80s. The plugs on them are NOT interchangeable. Easy access is by removing the RR taillight and liner. Mine was damaged so I had to go thru the two that did not match til I found the right one. Plug N play, it works fine now. One of them said Toyota, but mine is plain generic looking, so maybe port/dealer installed!?!
