trailer wiring harness on a 1994
granada hills,CA
hello, so i pulled a trailer wiring harness from a 1997 land cruiser a while back. i have a 1994, im wondering if its still plug and play for a 1994? if its not, how would i wire it up? i have the whole harness with all the male and female plugs. thanks guys
I got the wiring diagrams.
Brake light is a G-W wire
Tailight is Green wire
Turn signal right is G-Y
Turn signal left is G-B
I'm hooking up a 4 wire flat connector.
1 is ground and 1 is brake but the other 2 are signal. So which one does the tailight wire hook up too?
On a Toyota, you must use a converter to change the separate turn, brake & taillight signals into combined turn/brake/taillight signals. I don't know if the '97 harness will fit the '94. A quick look on etrailer.com says they are not compatible.
Hopkins shows a plug-in solution:
http://www.hopkinstowingsolutions.c...ota_land_cruiser_91-98_lexus_lx450_96-98.html
Otherwise you have to go with a universal one:
http://www.hopkinstowingsolutions.c...versal_kit_independent_bulb_turn_signals.html
typical wiring diagrams:
http://www.hopkinstowingsolutions.com/doc/wiring-guides.pdf
On my '93, it had a Toyota converter spliced into the wiring behind the right rear panel in the cargo area. The Toyota converters are known to fail even if they've never been used. I had to replace my Toyota converter with a universal one & just used the original splices. If I was doing it from scratch, I would try the plug-in one, but you will probably have trouble finding one locally in stock. Walmart & most auto stores carry the universal ones for Toyota applications.
I really appreciate the input fellas. From my understanding the 94's diddent have a plug and play system right? So if I get the hoppy 43405 it won't work even tho hoppy claims it will work?
Ok I got it all connected, how do I know if the converter box is bad? I'm using a test light and i can only see the tailight working, but not the turn signals or brake light.
FWIW, I originally installed the Hopkins 33405 wiring kit in my 1994 FZJ80 and then moved it over to my 1995 when I sold the 1994 80. Easy install and worked on both trucks without issue.
thank you everyone!! so i got it installed, it was easy plug and play. it turned out the converter box was bad. i bought a universal one at the trailer hitch shop. i destroyed the old converter box to pull out the connectors, i wired the new box to the original toyota connectors so i did not mess with any factory wiring and its still plug and play. everything works great, thanks alot fellas.
