Trailer Lights?
Sequim, WA
Does anybody know who makes or a company that sells trailer lighting harnesses for FJ40's. Something that would allow me to plug into my existing tail lights without spliceing wires.
Most likely you are wanting to get the equivalent of a flat four plug for your trailer, right? LC's wiring doesn't match up real well as you'll be converting from a 5 wire system to a 4 wire system. Hoppy Manufacturing makes the convertor.
There's a plug on the firewall which connects the rear lighting harness with the main harness. You might be able to tap into that plug there and get wiring back to the rear for trailer lights. I still think the easist would be to splice into your harness where it crosses the rear crossmember. For a little added insurance, use shrink tubing to seal your connections up tight.
About a year after I purchased my 78 new I was told that there was an adapter sold by Toyota that allowed one to connect trailer wiring at the rear of the vehicle without splicing. By then it was too late and I never checked it out. Let us know what you find out. If I ever rewire, I could use it too!
I've searched for quite some time and was never able to find the plug-in type harnesses. I'll probably just end up splicing into the existing wires back by the tail lights.
Yes you will.
Toyota makes a plug and play trailer wiring adapter for newer vehicls, but for your 40 series...you are not going to find that.
Good luck!
-Steve
Old thread....but trying to install a 7 pin female trailer plug on my '77. I am familiar with trailer wiring and have identified all the wires and the corresponding pins in the plug but, not sure about the brake wires. The green wire goes to the running lights (Brown) and the turn signals match up to the (Green- right and Yellow left) but where do the stop lighs go to. Logic says it would piggy back on to the turn signals wire but I am confused and need someone with a fresh brain to noodle this out, Thanks in advance for your comments
looking at the Hiker tear drop trailer.
most of the new trailer harnesses seem to share the bulb with the brake and turn signal. They are separate circuits on the 77. Personally,
I like the turn and brake to be separate filaments so I would rather keep the cruiser wiring style and replace the light assemblies on the trailer to match
You can use one of these if you want to keep the light assemblies that are on the trailer
If you decide to change the trailer lights you will also have to rewire the trailer. The addition of two wires, either turn or stop will have to be added to each side. This will totally screw up the wiring for any tow vehicle with combination signals (turn and stop on the same wire) as there isn't a converter to go from combination to separate signals that I am aware of.
Mathematically, that's two equations with three unknowns, so not possible. Remember that the brake signal from the vehicle is used to control the brakes and the lights, so any delay would be dangerous and emergency flashers light both turn signals at once.
I do not believe the OP is wiring in a Brake Controller, just the lights. A modern brake controller is actuated by a signal from the brake pedal, usually the brake light, and an onboard accelerometer. That is why there is a proper orientation marking(s) on the brake controller. These signals are combined, based on the user settings of the controller, into a proportional braking signal. The proportional braking signal is sent to the trailer brakes on a completely different wire. Therefore no appreciable delay.
Thought the seven pin trailer were factory wired for trailer brakes. Not sure but believe they also have a hot twelve volt wire to charge the battery in the trailer that activates the electric brake in the trailer if it brake loose. Would a trailer have a seven pin plug with out brakes? Only modern trailer I have is a car hauler with electric brakes on both axles. All my other smaller trailer use just the flat four pin plug. If the teardrop trailer has a seven pin without a brake axle would probably get a adapter to four pin and install a four pin on the 40 and call it good.
I have RV 7 pin plugs on all of my trailers, it makes it inconvienent for friends with only 4 pin flats from borrowing. It is dependent on if the trailers have brakes or breakaway systems if the wires are connected. On my 4X8 Fruehauf there aren't any brakes so I just leave those connections unterminated.
Above posts are helpful. To further explain my original question, the Hiker Trailer has a 7 pin male plug as it has electric brakes. Today I investigated a hydraulic brake set like on some boat trailers and that may be the most simple solution for my '77. It is not heavy enough not powerful enough to haul more than the 1600-1700 lb Hiker. @Living in the Past and @Cromagnon are correct about the power to keep the onboard trailer battery charged while in tow. Right now I just want to get the trailer lights operational with the 7 pin plug to provide power to the trailer and operate the lights properly. After talking to Hiker, if I supply the hydraulic surge brake parts they can install it in the hitch. We shall see is any of my confused thinking will work. In the aviation business I just call the avionics guy about anything electrical beyond the basic aircraft wiring.
It's really not confusing. You can wire in a 7 pin if you wish but you should use a brake controller rather than just constant full power
to the trailer brakes. Generally a controller can use a relay triggered by the brake lights to supply power to the trailer brakes . The controller can then be turned down or up to adjust for trailer weight. 12V to the trailer should be run through a diode of some kind
if your trailer has it's own battery and is dependent on your truck's alternator for charge. A battery isolator works. The purpose is to prevent the harness from melting down if your truck's battery dies and you are unaware. If your trailer is connected and you try to start
your truck with a dead battery it will draw from the trailer battery. You'll still have to use a 3-2 convertor to get the 7 pin layout to
work . I been dealing with the same issue working on a expo trailer project . Newer vehicles all have the seven pin harnesses built in.
It's harder to finder taillight assemblies that designed with separate turn and brake circuits. If you had an early 40 it wouldn't be an issue
since they share a brake/turn circuit . A brake light override is built in to their system. The 3-2 box is basically that, a brake light override switch.
@lcwizard - Thanks for your information...Just ordered one of those 3-2 converter boxes. Look forward to getting it working.
This is a helpful discussion. I’m in process of rewiring and restoring my 1976 California spec FJ40 harness. It has the original green connector trailer socket in rear of harness as shown. Is there a way to tap into this connector to add converter? While this is off the truck, I want to install trailer wiring socket. Is it fair to say that this OEM connector is removable as there is nothing made to connect to it anymore.
@BeerM3 would it be possible for you to snap a photo of the harness mod Coolerman made for you? Below is image of the rear section I’m rebuilding and on the fence about removing the green connectors.
Thanks,
Thought I would chime in on this one as it has been a source of many thrown tools over the years.
I have made many trailer hook-ups over the years for many different people. Trucks up to 1974 are simple as they do not have the separate turn wiring. simply wire in a 4,5,6,7 pin plug. For trucks after 1974, a three to two wire converter is needed.
I originally used the cheap converters mounted under the rear of the truck but quickly learned they were junk. They were in no way water proof and after just one drive in the rain they would malfunction. Add in salt, and you would end up with blown fuses every time it rained as the salt infused converter would become a dead short.
I then discovered that Curt Mfg. made what they claimed (at the time) was a water proof, powered converter and started using those. They worked really well for a few years, then would suffer the same death. (They now state you must mount it in a dry area INSIDE the vehicle) This would work in newer vehicles where it would easy to hide, but not in a FJ40. These also required me to build a new harness and incorporate the converter and power wiring into it which many thought was over all just too expensive. (Cost of new harness + cost of adding the converter.)
So last year I came up with a better solution. Build a harness that was stand alone from the rear chassis harness and required NO splicing. The Curt 56946 converter is mounted under the hood on the firewall and all you have to do is unplug the one or two connections on the firewall for your rear chassis harness, plug the adapter in between the main harness and the rear harness, route the trailer wires to the rear of the truck and connect the power connections directly to the battery through a fuse. I terminate the wires at the rear into a 6 pin water proof connector and make a 12" pigtail with a standard 4 pin plug or bare wires so you can wire in the 4,5,6,7 pin trailer connector of your choice. I have even made a harness like described above that included a Prodigy Electric Brake controller plug. The plug supplied power, ground, and brake signal to a standard Prodigy (and other brands) 4 pin connector.
Here is a pic of a stand alone harness for a 1978: This owner supplied me with the required rare connectors...
Now for the BUT... On the rear chassis to firewall connections, 78 and up FJ40's started using some of those no longer available sealed connectors like the 6 pin oval used on voltage regulator, emissions and rear tail light connections, and the three pin connector used on the rear chassis, heater blower and regulator. Because I need a male and female set of whichever connector your truck uses to make up the adapter part, and these are no longer available new, the only source is used and even that source has just about dried up.
Thanks for weighing in @Coolerman. The stand alone harness is a creative solution to the problem. It will take time to wrap my head around it as work/life get in the way of shop time.... I wonder if there may be another option.... What if a harebrained modification was engineered that included:
1/A second brake switch only for the trailer brake lights.
(have no idea if there is room at the brake pedal but a small pedal arm activated on/off switch is basic).
2/Turn signal adapter
(taps into the existing turn signal L and R wires)
3/Both brake light switch wires and turn signal adapter wires are routed to passenger firewall and connected to a 3rd rear harness connector and routed to the back of the truck.
Going back to my previous question. What did Toyota originally have planned to connect into the green connectors as shown above and again below in my 1976 harness? Does anyone have the original wiring diagram or trailer adapter or sub harness that was supposed to connect here? I understand Toyota did not properly apply this in the US market.
