Do you know when you'll have more front sway bar links in stock?
I'm wondering when too.
I have them at the coater now. Hopefully tomorrow.
J
Will this work for me with the Slee Diff Drop?Next up, high clearance radiator to diff drop skid plate.
J
AHC model with full tread.
WEBSITE PRICES HAVE SHIPPING IN THEM, EXCEPT FOR AN 18.00 PROCESS/HANDLING FEE AT CHECKOUT FOR SLIDERS
J
I did not re-use the stock bolts, myself. Best practice for safety would be to replace with the recommended grade 10.9 bolts.Tow points can be installed on standard bumpers. They replace the stock points and are significantly beefier than the oem. I will recommend purchasing the bolts tt sells for them. You can reuse the stock bolts on one side, but on the side with the hook, the OEM bolts are too long and won't work.
I am having a hard time sourcing the correct bolts for the tow points on an ARB deluxe. I bought TT's bolts but they are not long enough with the ARB. Any online sources? Thanks.
Thank you.Try www.boltdepot.com I've had great service from them even on just a few items ordered. That is, if you know how long you need them. They have the Grade 10.9
Thank you.
Hi
Couple of questions
Sliders: can you mock/block up ,on floor, and post an end view photo(s) of the sliders w/ full infill as they would sit installed on vehicle ? sides of frame bracket vertical ?
Looking for a set with low angle round tube for step . I've not been able to get a good visual from pics on you web site or threads
Front Tow points: do these work with the stock front bumper/fascia ? if so are spacers needed ?
2004 LX470 AHC deleted 85% DD 15% trails etc
Thanks !
Basic design has a 20 degree pitch. I can make them in other pitches or flat if that is what is wanted.
J
