Traction Control kicking on during normal driving
I have the same issue with my newly acquired LX470 and mine does have play in the inner tie rods. It scared the s*** out of me when I took a high speed banking turn on the freeway. I've searched a few threads and a few members point to the same issue with the inner tie rods and that solved their problem... Hopefully I can replace mine later this week.
I forgot to update my issue. I replaced both inner tie rods and this fixed my problem. They both had some serious play in them. Its been over a year and around 10k miles since the vsc brake application on a banking left turn at highway speeds.
New inner tie rods, New lower control arms (with new ball joints) and a Good alignment shop did alignment. NOTHING HAS CHANGED!! I'm seriously at a loss and very frustrated at this point. Im not sure what else to do. Can the steering rack fail internally causing enough play to cause this?
Is it possible that its not the front end? Something to do with the rear axle?
Were you able to resolve this?
Old thread, but I wanted to post my problem and solution. I've replaced just about every possible suspension part on the front end over the past few years. I recently bought new tires (285/75R16 Open Country RT Trail) and FINALLY bit the bullet on a new rack and pinion that has been leaking for years, and had significant play in the inner and outer tie rod ends. After getting my 2k cruiser back from the shop, it drove like new. Smooth, quiet, etc. One day when getting off the interstate and turning left slightly, I had the same beeping and traction control light flashing. I could only recreate this in a specific braking/turning/40mph turn. After reading a bunch and knowing that I've already replaced dang near everything that could cause this problem, I checked the tire pressure to find the shop put 40 psi in a couple tires, and 36 in a couple more. After getting them all down to the same 36 psi, my problem seems to be fully resolved. I suspect the difference in diameter of the higher-pressure tires may have caused the trac control system to act up? I'm not sure how sensitive it is, but seems to make sense to me. Hope this helps anybody else that runs into the same issue. As mentioned in this thread previously, be sure to check your tire pressure first!
Chiming in here, just had lowers/uppers/rack replaced. Drove fine for the last 2 days, just like poster above, felt great! But I took a sweeping left at around 40 and my traction control started beeping and engaged the brakes and pulled me hard to the right.
After reading all the wheel speed sensor threads/cv axle play/steering rack thread last night. Just went out to check PSI, 40-44 in them. Waiting for my first test drive now….
I still plan on having the sensors/wheel bearings checked by the installer as I wanted to check back in after a few 100 miles after all this work anyway.
Edit: After reducing pressure to down to listed 29/32 (was between 40-44 across all 4) I was unable to reproduce VSC/Brake engagement on the same road on two different trips today.
Update: Reducing air pressure did not resolve my issue, happened again on a different road, was unable to reproduce it before. Now VSC OFF fires up upon start up.
Work that just been done, OEM.
-R&R Rack & Pinion (old was leaking)
-R&R FDS
-R&R UPC/LCA
2.5 years back, OEM.
-wheel bearings
-hub flanges
-outer tie rod end
Fired up techstream for a quick drive last night.
-attempted vsc reset/code clear
-following codes came back: C0200, C1223
-Steering angle sensor stuck at 1150 even after making it to 40mph
-wheel speed sensor all read about the same
Next chance I get
-Test FR Wheel speed sensor with multi-meter.
Trying to nail down a sensor before I drop it back off at the shop, the open circuit has me thinking a pinched wire during R&R. I need it for a longer DD today while my vans getting inspected, hopefully vsc stays off or I may pull a sensor because the random engagement while rare is pants change worthy.
Edit: All has been good since a zero point calibration, tech stream wouldn’t set it for me, the shop tried FSM pin jumps. Ended up using the scanner tool to get it. So far so good…. Here’s hoping I don’t post here again.
