Ah, good to know . Thanks for the reply.It does; I had to replace the steering rack on my son's 2000 LX470 because of that failure. The dashboard kept lighting up like a Christmas tree every time I rounded a corner in the mountains. Very spooky.
Is zero point calibration something that applies to 98-02 LC or is that LX only ?Before diving down the rabbit hole, I'd try a Zero Point Calibration first, then if you still get intermittent Trac/VSC/ABS locking up the wheel, then follow all the suggestions above.
It applies to either variant. Easiest way to perform this is in tech stream (if you have it). There is a DLC pin out method but you'll need to look that procedure up in your FSM.Is zero point calibration something that applies to 98-02 LC or is that LX only ?
