For Sale Toyota 15B-FTE engines(FT engines not available)(from Toyota MEGACRUISER), MEGACRUISER tented, pick up type and many more JDM, ex-militarys available
Yep, unfortunately ft engine not available for the moment.
Hey, im doing some research on the BXD30's and might be interested in buying one in the near future. Are there part catalogs availible? What engines / gearboxes did they come with? I came across this on youtube and saw it was left hand drive, were these ever exported as lhd versions? is there any other toyota / hino that shares the chassis?
has this changed at all? might aswell ask a couple months later on the off chance
@theglobb, you might like the FTE better for your truck since you drive into the mountains a lot. The E will add fuel adjustment on the fly for heat and elevation which means less tuning you have to do each time you go from school to home.
@Nurik do the FTE engines come with the harness and ECU to run the electronics?
@BreckenridgeCruiser I want to get my hands on a BFTE because Mick Wallin in Australia has developed a 15BFTE stand-alone wiring harness. I have two of his 1HDFTE harnesses and this is the direction I want to go on my 40 swap…15BFTE with a front mount in a 40.
@bottombracket That would be so cool. I have a turboed 1HZ in my 44 and there is very little room for a front mount. Also the 40 series rad is maxed out on cooling ability with my setup so I need to upgrade to a super cooling rad.
With your setup, you can fit an AC condenser, front mount IC, and a super thick radiator.
That’s the hope. Need to organize a motor from @Nurik now!
That does sound pretty sweet! I despise electronics though... when they work, they are amazing, and when they fail it's such a painnnnnn. I bought an old Isuzu box truck for 2k a while ago and am in the process of swapping the engine into the Red Rocket right now, fully mechanical diesel! Much cheaper than any 15B variant I could get, just a lot more work and not as cool :/
@Everybody
Hello everybody.
Prices for container getting back to normal prices, so I start receiving orders for Megacruisers and other wholesale JDM parts.
+8180-8726-8787
Hi Nurik, do you have any BDX30 for sale? If so, what condition and price? Many thanks
Let me share with you about one more unique ex-military truck.
Same chassis with Megacruiser
Same engine and transmission with Megacruiser.
It has AC but Megacruiser just cooler/heater fan.
But this truck`s rear steering don't turn like in Megacruiser.
This car mostly used for troop carrying.
Loading capacity 1.5 t Thats why its called 1 half ton truck among military guys.
19 passenger seat.
Cab is soft top, bed also covered with tent.
Below photos: 1st my yard, 2nd photo from Wiki.
By the way,price for this truck is cheaper than Megacruiser. Fresh stock available now.
Any stock left?
Well my engines arrived today. Unfortunately one is an FTE. The ac brackets I paid $600 for are also just some compressor cores.
Anyone want an FTE?
want yes,
can make run....prob not without ecu
Anyone want an FTE?
What a drag. Did you order from this seller (Nurik?).
I think I remember reading the FTE version is mechanically stronger (internals) and improved in a number of ways over the FT version.
Maybe you can source a FT mechanical injection system for your FTE engine? Megacruiser FT pump is a Denso VE4/12F1725RND110 I think. If you can find someone who killed their engine but injection system is ok?
Personally I wouldn't mind the FTE version, but I'd want one totally complete with all wiring components/ECU etc. I'd also like to buy one with A443 and t-case from megacruiser, so it's an easy swap to 70 series.
