Would have preferred WD, but the OEM Assy insert is made with rounded corners sufficient to prevent most receivers fitting so the WD hitch set up wouldn't fit. Totally wanted to use it, but went old school, slow down easy braking and and just staying alert. I did have a Prodigy brake controller, and really had no issues. Through the mountains, with OD off the entire time, I averaged 10 or so MPG. Really not bad considering all factors. AHC was amazing throughout and kept her in low, NOT limp mode. Worked as designed, comfortable ride the whole time, and was awesome. The TT was actually a Murphy bed, so tongue was probably close to 600 lbs,
WD and sway will be better, but this is a rugged, refined, and capable TV!! I've barely broken her in at 220k miles....
