Towing with a km2?
I previously posted about the toyo m/t. It got good reviews.
But, id much rather have a km2. Problem is the 315 km2 is only available in a D load range.
Has anybody here had any experience with a 315 and towing? I'm gonna be pulling a small popup and occasionally my 6x12 enclosed trailer loaded with my construction stuff.
I'm curious how much sidewall deflection and stuff the d ranges have. I have lots of experience towing and shouldn't even really be asking this but I figured wth.
Thanks in advance
Will
My Cooper 37" STTs are a D rating which for them is 3500# per tire= 14000 #. I would not worry any about towing what you have mentioned. A 315 D rated tire should not be too much less than that.
The km2s are rated at 3195.
Do you like your coopers?
The 255/85 R16 KM2 is an E rated tire, although you'd lose an inch or two in diameter over the 315. They're also not currently available pending some sort of revision by BFG.
If you tow the full 5,000 lbs capacity and had a heavy truck (>6,000 lb) you would be pushing at the upper limits of 4 D range tires on the truck (12,780 lb), although some of that weight would also be carried by the trailer tires.
With the 255s, I add about 5 lbs psi to the truck's rear tires when towing and things seems to handle well then, going from 45 psi to 50 on the rears.
I currently have 305 nitto terra grapplers on it. They were on it when I bought it. They're an e. I aired them down to max d psi and it sucked towing. That's what got me concerned.
On some job sites it's easier to take the 80 to haul materials. My ton ford is 2wd. Anybody with any dually experience knows what a 2wd dually can't do.
I caught dad towing 7500lbs behind my last 80.
It's not a normal thing, but when I need to tow, I really need it.
Price is the same between the km2 and the toyo. The toyo has great reviews for both off road and longevity, but they weigh a friggin ton. And we all know what extra rotating mass means.
Thanks again for all the replies.
Will,
You weren't feeling what the max psi would ride like in a D tire by lowering the psi in an E tire to the D max PSI. The carcass is likely different enough overall that you get an approximation at best.
Then again, if you plan to tow close to the truck's tow capacity, you don't want marginal. inkpot was right to clarify my garbled statement, which didn't clearly differentiate between tongue weight and GVWR. So you shouldn't get more than a significant fraction of the trailer weight on the rear tires. Howard probably said it better, in that you want minimal deflection of the tire by increasing the PSI. That 's what you're probably feeling, that the weight transfer to the truck rear axle is more than you really want in terms of the deflection. However, you won't get a clear picture of what the D rated tire will perform like.
