torque spec
Crush washer'd fill plugs don't have a torque spec that I recall ever seeing. Gut-n-tite.
Diff Plugs are 39 Ft-Lb
T-Case is 14 or 22 Ft-Lb
That's what I have written down in my FSM. I don't recall why I have two values for the T-Case though. It's aluminum, where the diffs are steel, which is why it's different.
Be sure to buy new crush washers (two different kinds IIRC), and remove the fill plug before you remove the drain plug.
"Written down" meaning that's the torque value you assigned to them? Would make sense but just want to clarify.
I found the values elsewhere in the book and wrote them down in the maintenance section.
I did find the T-case values, and it does show two different values as I wrote down. Front case and rear extension housing at 14 and 22 respectively.
And the diffs are from the specs at the back of Suspension and Axle under Torque Values.
I believe 22 or 24 is what I found as well for the TC. Crush washer the same as diffs if I remember correctly.
Transmission: 19ft/lbs
Diffs: 36 ft/lbs
transfer case: 27 ft/lbs
Diff are 12157-10010
T-Case are 90430-A0003
As ordered from CDan
Diff are steel crush washers much like on a spark plug.
T-Case are single layer aluminum washers.
And the hex plugs are 90341-18021 x6 for front and rear diffs and transfer case.
I finally got around to buying the hex plugs. Cant wait to put them in!
This thread is making my rethink everything I ever wrote down.
No kidding. Do these values change from year to year? I compared my paper copy of my 1996 manual with the pdf copy from birfmark (also 1996), and they agree with each other.
