Torque Converter install.... Help Needed
Erie
My truck is a 97 lx450, trying to re-install the torque converter onto the transmission. The FSM says "1. CHECK TORQUE CONVERTER CLUTCH INSTALLATION Using calipers and straight edge, measure from the installed surface of the torque converter clutch to the front surface of the transmission. Correct distance: 15.7 mm (0.618 in.) or more If the distance is less than the specifications, check for an improper installation. 2. INSTALL TRANSMISSION TO ENGINE Install the transmission with the 7 bolts. Torque: 72 N·m (730 kgf·cm, 53 ft·lbf)". I have done all of this but when I look at the flex plate, it sticks out well over an inch from the mating surface on the engine so clearly the torque converter isn't recessed far enough to allow the transmission and engine mate. Am I missing something?
Here's a couple pics:
Hope these help...
Flex plate definitely installed correctly. Spun the Torque converter while putting it on. Definitely isn't seating properly, opened up another engine and tranny we had on hand and confirmed that it wasn't seated all the way. Tried for hours to get it seated and never got it lined up. Ended up using the other tranny.
Use one hand to support the center nub of the converter, use the base of your other palm in an upward motion to not only spin the converter but gently push inward while spinning it. When you have it all the way in you will not be able to fit your finger between the converter and the bell housing.
My father and I tried for hours yesterday doing exactly what you said @ChiTown . Read many things on the internet, watched videos, talked with Georg at valley hybrids. Couldn't ever get it to line up and slot in like it was supposed too. Wondering if the torque converter isn't messed up somehow. Thanks for the input everyone.
