I did something similar using a thin sheet of industrial reflective insulation below the rubber grommet/boot (between the floor pan and the boot), the idea being to reflect some heat away from the rubber hoping to prolong it's life a bit. It required cutting a couple of flaps in the reflective sheet around the mini-boot for the shifter bracket that dives down below the floor pan. It has decreased the temp of the shifter assembly (plate) a few degrees.
What were the specs for the material you used, brand??
33555-60071 answered my own question....
