Can someone clarify or confirm this for me?
Top dead center before the head goes on has piston 1 and 6 up, the crank key at the bottom and the pulley at 0 on the timing cover. I got this part.
Top dead center on the compression stroke doesn't apply until you have reinstalled the head and cams, and have them positioned with the two dot marks level with the outside of the head, and the single dots lined up inside the head and the tining sprocket remounted to the intake cam. Is this right?
This connection of the cams to the crank is what makes it the compression stroke, right?
