Tools - where to get?
if you want a 3/4", i believe matco/snapon trucks have them...
you can get a 54mm socket (most of them are 1/2" drive) from cruiseroutfitters, marlin, slee, etc...
i would go with the 1/2" drive since that's mostly what you need for our trucks. there are always adapters that can go from 3/4 to 1/2 and vice versa...
I need a 54mm impact socket
JT, you don't need an impact grade socket for the front axle job; just a plain-Jane socket will do......and lots of paper towels.
C-dan has a Toyota version, your local Snap-On driver may have one on his truck, most auto parts stores can order one (NAPA, etc) or Sears Craftsman 2 1/8 will do the trick. All are around $20 or so. Not sure what your choices are for 3/4 inch drive, but do not use an impact wrench on this nut. An impact socket will most likely be too thick to fit anyway.
C-dan has a Toyota version, your local Snap-On driver may have one on his truck, most auto parts stores can order one (NAPA, etc) or Sears Craftsman 2 1/8 will do the trick. All are around $20 or so. Do not use an impact wrench on this nut.
2X on Snap-On having one on the truck. However, be sure to ask for the Blue Point stamped one instead of Snap-On forged one. $30 instead of $230 for the socket. These are not 'high torque' so the stamped steel one works just dandy.
Thanks guys. Did some surfin' and found a low torque 54mm socket at wabfab for $14+ s&h. They convenientlly have a cheap pull-scale as well. Can't really beat that...
Say, what size hub nut does the rear have?
jt :wrench:
The rear? Funky. it's a round nut with 3 holes for an SST wrench in it and an indexing screw. It requires a special service tool = SST.
You can order the real SST from Cruiserdan or you can make one. Either way, you aren't going to buy an off the shelf socket that will fit it right out.
