I just finished a total front end rebuild (brakes, knuckle bearings, seals, wheel bearings, TREs) on the 1987 FJ60. It drives straight but is very sensitive to turning either direction. When you look at it from the front, there is an obvious "V" appearance to the front tires with the lower aspect of the tires being closer together than at the tops. I have not checked toe in yet but will do so. It is a stock original suspension with 130K miles. The tires are 31X10.5X15 BFG ATs, brand new.
I kept the knuckle shims with the appropriate steering arm or cap, everything was torqued to spec and preloads were set with scale. I got my bearings from Marlin (on sale).
Am I in deep s**t? The stuff with the SSTs in the FSM looks extremely complicated in regard to adjusting the knuckle alignment.!
it's maybe a half
jof
