To Cruiserdan
Lebanon
i Pm'd this post to Cruiserdan, but i think his box is full,s i will try the forum instead. sorry if i broke any forum rules.
Dan,
I bought 2 locked axles for my 1fz-f (not EFI) 1992 cruiser (foreign car Middle East spec), so lockers were an option on it(but not on mine), my truck is a manual h151f transmission.
I need the ECU (89533-60030), the diff-lock switch (84725-60020), and do I need a harness from the back to the driver side, or I can fabricate connectors (spades) for it.
Another point I have no central diff-lock button it’s a manual transfer case (2h-4h-4l), do i need to order any other parts, or by shifting to 4l by default it locks the central diff.
P.s. I know there is no higher authority on cruiser parts than you, so please help a cruiser head.
Frank
Frank, your transfer case is not a full time case, there is no centre diff to lock.
so even if i installed the 2 locked axles they will still not be fully locked,
it will not split 50/50 when i put it in 4low, so if the front slips the rear wont help out right, and vice versa if rear is slipping the front will not help.
i have to lift it on jack stands to make sure i guess.
I would assume that if there is no slip in the TC, being manual, you are effectively always "centerdifflocked", i.e. no worry there. As long as you would have both tires on one end with traction, you'd have overall traction. If you lose one tire traction on each end, then you'd be stuck unless you have end diff lockers.
With a part time case, the "center" is "locked" anytime you are in 4h or 4l. It is a traditional transfer case, not a differential like on the fulltime 4wd models.
Thank you e9999 and Firetruck41, you guys clarified the issue for me, now all i need is to get the switch and the ecu from Cruiserdan for the lockers, then i would be fully locked rear front and center by default when in 4l or 4h.
Yup!
