I actually like those things. Apparently the axles are tough as heck. Cool truck for a good deal imho. I think the Aussies like these.
I thought you might… and you’ve mixed enough blood with cruiser parts that we’d even let you hang around if you bought it. I would at least… can’t really speak for the others.I actually like those things. Apparently the axles are tough as heck. Cool truck for a good deal imho. I think the Aussies like these.
You could probably slap a Toyota hood ornament and a couple Landcruiser emblems on it if need be
Based on a 2 minute google search those turbo diesels seem to be good… unlike yours that you’ve gone to such lengths to make “reliable”.
These days a decent Diesel 4x4 for less than 10k seems like a rarity… and it sounds like there’s enough spare parts with it to keep it going for a long time.
When i searched TD42 it seemed like it could be a turbo. That said, other articles indicated the engines of that vintage were somewhat better able to withstand aftermarket Turbos (pre ‘94 or something similar). Post ‘94 had thinner pistons and rods or something like that (couple days since I skimmed through the article) and I’m not overly interested in doing a bunch of research on something I’m not interested in buying.I don't think the motor is turbo. When people do turbo them, they have all the problems of the 2LT apparently. Overheating, cracking heads etc. The problem is IDI diesels across the board all manufacturers don't take well to turbo+high loads because of the pre-combustion chambers in the cylinder head (inefficient dump heat into head/coolant). That's the common denominator: the fundamental technology.
Normally aspirated the IDI diesels are great though; even the L series like 2L/3L/5L.
All Toyota's turbo diesels in HD Landruisers are direct injection (DI) which is why they're fine.
But yeah, as cool as those trucks are, I'd be starting over again on maintenance/upgrades and I don't think would gain much at the end of the day. Now if that motor was turbo diesel direct injection, I probably would consider it, as that would be a huge advantage.
Hopefully that truck/parts goes to a good home though.
TD42 engine: Your guide to the Nissan turbo diesel motor
Nissan’s TD42 engine as seen in the GQ and GU Patrols of the late 1980s and right up to 2007, was kind of the black sheep of the TD engine clan. But not in a bad way.www.carsguide.com.au
I’m thinking the TD42 is a turbo… it looks like stock it does well, but modifications and hard use lead to issues.
But I very well could be wrong, and to be sure that exact one is, contacting the seller would be the easiest way to find out for sure.
Under your knowledgeable hands it will run forever. No worries.Thanks for looking into it! In any case, I'm holding off on a new vehicle for now. Mortgage done in 1.3 years, then depending on how the LJ78 is doing, might start looking. LJ has been running fantastic thankfully.
That's kinda cool. Perkier engine than the one I had (it was a dog) but 250hp seems like a reach...View attachment 3295112View attachment 3295113View attachment 3295114![]()
2000 Nissan Frontier
American D22 frontier with a td27t from a 90 terrano, and qd32 transmission . 150-160k km on engine 170-190k km on trans. Turbo whistle sounds 👍🏼 Jdm motor and tranny 🔰 All other parts are...www.facebook.com
2000
Turbo Diesel
160k
$11,500
@GTSSportCoupe
That's kinda cool. Perkier engine than the one I had (it was a dog) but 250hp seems like a reach...![]()
This one is even a LHD…
Doesn’t seem like a terrible price considering what garbage goes for these days.
250 “vacuum” hp… like my 5 hp peak shop vac that is rated at 10 amps.from a 4 banger diesel
I can't say... I don't fit in most imports. They're not built for 6'4" 270ish.They're kinda s***ty trucks to drive those 2000 ish frontiers to be honest.
There was one at work, it really sucked...mind you it did have the maintenance department looking after it![]()
He's probably just wrong.Thanks!
Yeah he’s on it, we are going to have a look at it tonight.
1988 3B?? Don’t think anything that late came to Canada with the 3b maybe 13BT??
forum.ih8mud.com
It sell that quickly?
Seems like the page is gone
