TJM T17 bumper with fogs instead of indicators
Looks Great! My bumper should be delivered tomorrow, do you have any pics you can share of that winch solenoid placement? I've got the X20 12k ready to go.
I just mounted mine yesterday. I’ll grab a photo of how I Jerry rigged mine after my appointment. In short I mounted it to the power steering coils on the right side (left side when looking at the front bumper) and it fits perfect. The o my way I saw mounting it on top of the winch was to cut the front core support that holds the hood latch (There is a gusset from the factory thats in the way) and I didn’t wanna do any more cutting that day. I would be interested in see how others mounted there’s
Do you have a pic of where the mounting point ended up? It almost looks like it would fit if it was mounted offset to the winch? Passenger side?
BTW...did your bumper come with the top "TJM" cover? Mine didn't.
Got it, thanks! Didn't realize how far back the winch sits. I'll post some pics when I dig into mine. How much trimming do you need to do under the headlights?
I cut out from the middle ish of the Driving
just used some plastic wire ties to place it on the right.
I took the left bracket off the solenoid pack then tried to tie it down si it wasn't over the rope drum. When off-roading you need access to the drum to sort out build up problems
@molonlabemike did you remove entirely the trim piece under the grille? I’m about to buy the TJM to replace a cracked OEM and I’m trying to figure out whether I need new trim pieces under the grille and L headlights, which are also cracked. Sounds like yes (new) under the headlights, which I’ll trim, and maybe no under the grille? Thanks!
I just trimmed the metal underneath the plastic trim. Once you test for the bumper you will see where you need to cut. Pretty easy
Thanks. Sounds like I need new trim pieces, which I‘ll install then trim when the bumper goes on.
Another basic question (and probably in the wrong thread) but I assume the metal bracket under the grill and below the headlights stays on with a TJM install? Is that the metal than needs to be trimmed? My bracket got mangled in a fender bender and if it needs to stay I’m debating whether to bend back in place or source a new one. Looks like this is how the trim filler panels below/around the headlights stay in.
On my 99 that bracket is totally clear of the bumper
