TJM Push Guard
Still loving it. I think it goes well with RW and BFG KO2s. No lights yet bit thinking about it. Don't want to over do it
Thanks
How hard was it to take the grill off, and how long did it take. I was going to have someone install the bar for me when they put on the lights
To take the grill off:
1. Take the top cover off by pushing in small button on each of the plastic retainers then theythe can be pulled up with fingers. Cover comes of in 1-2min
2. Unscrew 3 zcrews from top edge of the grill wgich was covered by cover. 1min
3. Probable the most difficult part is tho remove the grill. Now it is retained by plastic clips. Look inside and you will see how they are aligned and work. I pushed them in the correct direction and grill comes of forward. Drivers side is easy as u can see all the clips. On passenger side they are in the same spot but obscured by some kind of air intake. However i was able to pushh them with a finger/screwdriver. Took me 30 min. To do it 2nd time 5 min
4. Grill goes forward but limited by wire sttetch to the camera. I did not disconnect it. It was enough to insert the brackets and drill 2 holes.
5. Lower brackets should take 15 min. But took me around 30 due to left/right labeling confusion. You have my photo of it so it is straight forward.
Thanks buddy. I think there is a kit to move the camera incise my lights block it .
Thanks a lot for your help. They say it sould be shipped out on Tue .
I received my Push Bar today. I just dropped off to get powercoated . I hope to get it back within 2 weeks. Then I will install it along with lights
Thanks for your help
The camera is partially blocked by my bar and lights. I am not sure about the radar . How would I know ? I am not getting any warning light about radar being blocked .
I did not have time to wire up the lights . I also might put a smaller set of light on it also down on the plate.
Thanks for reply. I guess the cruise control would not work. When i get too much snow or rain covering "toyota emblem" i get the light warning and cruise doesn't work.
When I get home I will try the cruise control .
I am not sure if 2 sets of lights would be to many lights .
No such thing as too many lights :p
I agree. I am going to get it powercoated . I will try to make it a little different .
I just wanted to say your bull bar looks pretty bad a$$, especially the black!
