DTT and Chimyz:
I'm ordering the skid plates through the group buy that's going on, and will order the slee sliders shortly as well. As far as suspension work, I called RadFlo today and will most likely be installing front remote reservoir coil-overs (2" dia.) and rear shocks to give a 2" body lift. Adding TotalChaos UCA's as well, of course.
With 35" tires, that gives another 2" radius over the 31" stocks. Therefore, I should gain about a 4" lift bringing the clarence from 9" to 13".
Curious though, why you both went with 33" over 35", when the LC should support a larger tire? I'm sure you guys both have good reasons.
I like the BFG T/A's (either the KO or KM2) on 17" TRD rims.
Any suggestions that either of you have learned through this process?
