Tires after lift
Marlboro
I just got a three inch lift and I wanted to get tires but u can't get to big tired or I'll have to re gear my truck can someone help me I want 35s idk f they will be to big tho
^^agreed. 33s looked small on my j lift fwiw.
Under 5k' elevation and in flat lands you'll be fine. Above that or in a hilly region you may desire gears more but still drive able with some pwr and 3/2 action. Until you add a tone of gear and armor and want to head higher into the hills or pull hwy passes at speed
Marlboro, where is that?
This question is entirely dependent on your location.
Lots of rigs here still run stock gears over 35-37 inch tires. We go from 2000 to 7500 altitude with no real problems. Learn to use the shifter and don't be afraid of rpm over 4000. That's where the power band tops out, so use it!
I'm not willing to drive in the right lane with the semi trucks, so I bought 265 tires until the turbo goes on. I would not recommend 315 with stock gears to anyone living above 6,000 ft elevation without a motor swap or forced induction. Sure, some people do it. Some might even say it's fine, but I sure as hell wouldn't want to. I have spent too many years driving a 22r mini truck or 2f 60-series. There is no looking back now!
That's just my take. BTW, I leave it in 2nd driving over Vail pass with 265's and still struggle to maintain 60mph.
If at lower altitude most of the time, I imagine it would be a much easier proposition.
I've written this before, but I felt that 35" AT's with Alloy wheels is totally doable. Changed to steel wheels and Toyo MT's (heaviest tire I've ever felt in my life) and now I am hurting for power in elevation.
